Sorry, I've just been informed that tables were greatly improved in 2007. I
didn't realize 2006 lacked so many of their features. 😕
wrote in message news:5714411@discussion.autodesk.com...
Can you attach some printscreen where this option is? I've got polish
version of ACLT'06 and I've tried to select single cell, subset of cells and
still I've got the same options (I try to translate them, but the option can
have different name in your AC):
- cut
- copy
- paste
- last entries
- position of text (upper left, upper center, upper right etc.)
- cell border
- match cell
- insert block
- insert expression/formula
- text edit
- insert column
- delete column
- adjust columns (*)
- insert rows
- delete rows
- adjust rows (*)
- delete all changes in properties
- delete contents
- merge cells
- split cells
- properties
(*) when subset is selected
Best regards
Mateusz
ps. thanks for patience I've appreciate it
