AutoCAD LT Forum
2015LT - Screen flicker
6 REPLIES 6
nicks
3412 Views, 6 Replies
I've recently upgraded from 2014LT to 2015LT and now get horrendous screen flicker when moving, panning, rotating, zooming etc. This didn't happen in 2014LT.
Anyone out there got any ideas that might help solve the problem?
6 REPLIES 6
AcadAdamLT
in reply to: nicks
Try turning off Hardware Accelaration.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
drjohn
in reply to: nicks
My want to check out this thread if you have the time.  It's quite long.
Hope you find something there to fix your issue.
HTH
DJ
nicks
in reply to: AcadAdamLT
AcadAdamLT,
Thanks for your suggestion. I've tried all comsbinations of hradware acelleration on/off and smotth line display on/off but to no avail.
What's puzzling is I don't have the problem when using 2014LT which suggests the issue lies with LT20156.  From this forum and other sources it seems to be a common issue.
nicks.
nicks
in reply to: drjohn
DJ,
Thanks for the suggestion. Took a look through the thread, turns out I'd already tried most of the suggestions but without success. Could be my graphics card but whether the I.T. police at work will replace it remains to be seen.
nicks.
braudpat
in reply to: nicks
Hello
Welcome to the Autodesk/AutoCAD Forums !
Have you a NVidia graphic card on your PC ?
If YES, have you tried to DISABLE the "FXAA NVidia Anti-Aliasing" feature ?
Then relaunch your LT 2015 ... and test ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
nicks
in reply to: braudpat
Pat,
Thanks for the suggestion, sorry it's taken ages to repond.
I've checked what type of graphics card I've got, I definitely don't have a NVidia card.
My PC simply states Intel(R) HD Graphics 4000.
From a quick look around this forum and others it looks like I'll need our IT dept to install a decent graphics card to solve my problem.
Nick.
”Boost
