AutoCAD LT Forum
2015 LT
3 REPLIES 3
299 Views, 3 Replies
2015 LT
Installed this version a few days ago and the following is leading to user frustration. Note: installation was done with firewall blocking off and received a clean install message to both the software and THE SP1. The screen command to turn cursorbadge off does not work and doing my best to ignore this distraction, I have discovered a problem with polar arrays. When (2) items are selected about an intersection or circle center, multiple items are displayed with a message of trying to array more than 10, 0000 items.
I am open to suggestion on how to remedy these items, but would prefer to not poke around in a registry.
Anyone know if drawing icon color options will be a future offering? The red is too close to the adobe .pdf files this company stores in the same project folders.
Thank you in advance for assistance,
                                                         Craig
Tags (1)
3 REPLIES 3
pendean
Post a DWG file with the array/selection issue, cannot replicate it here.
You can edit and redraw all the icons you want: it's a daunting task so there is no shortcut for it. CUI command and help yourself.
in reply to: pendean
The array (polar) has to be a software code problem, either fractured in program download or changed with the SP1 addition. The color comment concerns the X.deg file as stored which is a red icon.
pendean
You can change Windows Explorer program file icons if that's what you mean: always been a feature in Windows, there are even freeware for complete substitutions.
If you think the problem is core to 2015 then report it to Autodesk direct as a flaw: posting here about it is not relevant as we are all end users just like you.
”Boost
