Hi Leon,
Thanks for the update.
There are still a few possible causes to this error. Please try the following tests to help narrow it down:
1. Test AutoCAD in a new, local, admin account. The steps can be found in this link:
http://windows.microsoft.com/en-us/Windows7/Create-a-user-account
2. Reboot into Selective Startup. Here are the steps:
a. Go to the Start menu > Run
b. In the Run box, type MSCONFIG and click OK. This brings up the System Configuration Utility
c. Click the Services tab at the top
d. At the bottom (just above the OK button) click the Hide All Microsoft Services checkbox
e. Make a list of any unchecked items so that we can reset it when we're done
f. Click the Disable All button
g. In the unchecked list, enable FLEXnet licensing service to turn it back on
h. Click the Startup tab, make a list of unchecked items, and click the Disable All button
i. Click OK and restart Windows when prompted (just click OK on any permission error you may get.)
j. After rebooting, close MSCONFIG with the X in the upper right
3. If the issue continues, remove and reinstall AutoCAD from the new account while in Selective Startup.
Please let me know if this works for you or if you have any questions.
Best regards,
David Dyche
Autodesk Support Team
