>I create a dxf file select the objects, but when it gets open on different
>machines the only layer there is the outline, there are no text or
>dimensions.
Mark,
what software do they use to open the DXF? You can't do much wrong
when creating it. The DXF contains all the selcted objects including
text and dimensions. It may be that their software does not understand
the most recent version of DXF. They will have to check with their
software manufacturer. You may try to select a different (older) DXF
format (e.g. R12/LT2) to see if they get better results then.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
