AutoCAD LT Forum
text scale for template
7 REPLIES 7
Message 1 of 8
alex.gotthelf
397 Views, 7 Replies
I am trying to set up my template for architectural drawings.  I would like to use annotative text and dimensions and leaders.  I have selected a font and am trying to set my Paper Space text height to 3/32" so all drawings in all scales have text of 3/32".  When I type in 3/32" it returns a value of 1/8".  How do I get it to recognize the 3/32" value. Also if I save this in the dwt file will it always be set for this?
ag
7 REPLIES 7
Message 2 of 8
Go to UNITS and change the Precision value to 1/32 instead of 1/8.
2. Yes
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Message 3 of 8
accept solution. One problem though; my text for leaders says 3/32" but it comes out 1/8". When I double click on the text box it shows 6" (at 1/4" scale) not 4 1/2" as it should.
ag
Message 4 of 8
Are you using MLEADER or QLEADER?
From the Dropdown; Format; MLeader or fromt he Command line: MLEADERSTYLE make sure the text height is set to 4-1/2".
If you have defined a height for this Text in the Textstyle manager this box will be grayed out.
(check the box on the bottom right of the post Smiley Wink)
Message 5 of 8
Thanks. I am using MText or MLeader. I tried qleader and it came out the right size. I'm not sure why you use one over the other. The mleader seems to be the default and there is only a Block or None option in the styles. The grayed out box says 3/32". Should this be set to zero in the text style?
ag
Message 6 of 8
pendean
in reply to: alex.gotthelf
Post a DWG file with the problem MLEADER in it, add instructions inside the fil to shwo what you want vs. what you got.
Message 7 of 8
alex.gotthelf
in reply to: pendean
Accept as solution
ag
Message 8 of 8
On the bottom right of each post in the Thread is a place to select the Mark as Solution.
Doing this step will allow the post to show how it was Solved and will provide the telltale Green Check.
”Boost
