AutoCAD LT Forum
system halted after doing Regen or Zoom
6 REPLIES 6
hgf_21_xy
470 Views, 6 Replies
Hi guys,
I'm facing a problem that each time after I did Regen or Zoom, the system halted and then recovered only after several minutes. I guess maybe it is related to special drawings, because it only happened when working with the drawings which was transferred from an .iges 3D drawing. Anyway, it is a really a pain for me.
Did anyone meet the same case by accident before? Could you share with me the real cause and solutions?
Thanks a lot!
-Ken @AutoCAD LT 2010
6 REPLIES 6
braudpat
in reply to: hgf_21_xy
Hello
Just a few ideas :
1) Have you purged theses DWGs ?
Command: PURGE
2) Have you tried to open these DWGs in Recover mode ?
Command: RECOVER
3) Maybe you could install the SP 2 for ACAD LT 2010 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15073321&linkID=9240818
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
hgf_21_xy
in reply to: braudpat
Hi Pat,
Just tried and it has been proved that it does not work with "PURGE", and it did work with "RECOVER", however, some line and arc segments were lost afterwards. At the end, I installed the SP 2 and it works perfectly now without any side affects. By the way, do you know what was updated in SP 2 by Autodesk?
Thanks a lot!
-Ken
braudpat
in reply to: Charles_Shade
Hey Charles
I will give you a "pseudo" Kudos as the "ReadMe Manager" ...
Bye, Pat
Patrice BRAUD
Charles_Shade
hgf_21_xy
Hi Pat and Charles,
Thanks very much for your help!
Hope to have more communications with you in the future.
-Ken
”Boost
