AutoCAD LT Forum
setting main library or dictionary
9 REPLIES 9
Message 1 of 10
Louis2930
271 Views, 9 Replies
Having problems setting a dictionary in 2002LT. Using Tool, Options, Files, Dictionary - can't get the main or custom (.cus) to set. Is there any default dictionary in this Autocad Version? Also, attempted to use the main Word dictionary but couldn't find any others with the *.cus extension for Autocad?
9 REPLIES 9
Message 2 of 10
in reply to: Louis2930
Make one: use Windows NOTEPAD, type in a word, save the file with
a CUS extension.
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"Louis2930" wrote in message
news:f11909f.-1@WebX.maYIadrTaRb...
Message 3 of 10
Louis2930
I tried with notepad & .cus
It wouldn't load into the main dictionary so I linked it into the custom dictionary. (the main wouldn't allow me to choose or browse anything)
When using spell, it still comes back with the message - no dictionary specified, could not start speller.....
Any other options?
Message 4 of 10
Do a repair install of LT2002: back up your ACLT.MNS file first.
Dean Saadallah
Expanded Links Page
news:f11909f.1@WebX.maYIadrTaRb...
browse anything)
> Any other options?
Message 5 of 10
Louis2930
Thanks again. Tried the reinstall and still no success.
Any other options? What about the process to link to MS Word?
Message 6 of 10
SPELL command, select some text, use the button on the pop-up to make the
change: HELP explains more about command usage. WORD's help tells you what
your dictionary file is.
Dean Saadallah
Expanded Links Page
news:f11909f.3@WebX.maYIadrTaRb...
Message 7 of 10
Louis2930
I've been using autocad lt for many years. Never had this come up before.
When I try and use the spell command, I get the error:
NO DICTIONARY SPECIFIED, COULD NOT START SPELLER.
Any other ideas? thanks
Message 8 of 10
Do a full un-install of LT as outlined in HELP: remove all traces in the
Windows registry, the Shared folder, everything and everywhere. Restart your
PC. Log in as ADMIN (if in Win2000/NT4/XPPro, and if not, upgrade), turn off
all running apps, do a full install.
If that does not work, back up all your files, wipe your harddrive clean,
and start all over your Windows is messed up.
Dean Saadallah
Expanded Links Page
news:f11909f.5@WebX.maYIadrTaRb...
Message 9 of 10
Louis2930
That resolved the problem.....
Message 10 of 10
Glad we finally nailed it 😉
Dean Saadallah
Expanded Links Page
news:f11909f.7@WebX.maYIadrTaRb...
> Thanks,
”Boost
