1. Stay away from the "RegClean" utility.
2. Check if you have many and/or long path's in the "Support Search Path"
settings in the Options dialog.
btw, installing in another directory doesn't help avoiding registry
problems.
The installation always ends up at the same place in the registry.
Conny
"Carl" skrev i meddelandet
news:EF5227BB859767177B397D72A5CCB86C@in.WebX.maYIadrTaRb...
> When I select an object, "No Selection" is displayed in the Properties
> window. The Properties window remains inactive; I am unable to modify
object
> settings through the Properties window.
> I have followed article ID: TS45252 Remove all Autodesk® software
> products from a system to ensure a clean installation, the problem still
> exist after that.
> I have uninstalled all Autodesk program with the Add/Remove Programs
applet
> in the Control Panel, and then reinstalled it to a new location on the
disk
> to avoid the registry problem from affecting the new installation, but
same
> problem occure.
> Is it a DLL problem?
> What to do next to make it works again??
> Carl
