Show only
Search instead for
The Preview is a static snapshot image buried in the DWG file when it was last saved. It is not and never has been in any way, shape or form a look inside a DWG file. You are misinformed. Post it here for others to try and in the meantime fund it's BAK file to rename and recover, or your backup of the DWG file from a day or week before, and look to see if there is an autosave file you can recover too.
