In LT, you do it one at a time, manually. Part of the savings that is LT
over full AutoCAD.
No, the pulldown does not behave like the Layer pop-up.
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
"rs" wrote in message
news:3E252CA2.91254A7E@yahoo.com...
> Hello all,
> I use my "named layer filter" sparingly, but receive drawings with at
> least 20-30 odd named layer filters which I don't need. Is there a quick
> way to remove all "named layers", except those created automatically by
> my LT and subsequently by myself?. The information must be stored in a
> file within the LT program. If so, can I delete the unwanted "named
> layers".
> Also. Using the "named layer filters", I invert the Xref'd layers and
> therefore only see the used layers of my drawings if I open the Layer
> Manager. However, if I want to see the layer names via the the pull down
> tab above my drawing I still have to trawl through 280 layer names. Is
> it not possible to see the same as if opening the Layer Manager?
> Richard
