AutoCAD LT Forum
mouse wheel
4 REPLIES 4
426 Views, 4 Replies
mouse wheel
Dear All
I am having a problem with my mouse wheel function in autocad LT 2011.
The mouse wheel is zooming the wrong way. When I move the mouse wheel forward, the screen zooms out not in!  However the mouse wheel is working correctly in other programs, so i believe the problem is in autoCAD LT.  Mbuttonpan is set to 1.  When I hold the mouse wheel in, the pan works fine.
I have also tried other mouses with my computer, and they all have the same problem....  I'd be grateful if you know how to solve this problem!!
Tags (1)
4 REPLIES 4
Thanks, that is it sorted 🙂
Do you know how to change the defaults so that the zoomwheel setting will always be the same each time I open autocad LT?
Charles_Shade
ZOOMWHEEL is a Registry setting and should remain as set for all sessions of CAD once it has been set.
Does this not remain so for you?
”Boost
