Howard Walker
Need some guidance or help,
I have an old Archive paper copy drawing that has been drawn up in inches and there is no DWG Versions of it.
So I have been doing the basic way of using the calculator and converting the written dimensions down (inches) and then doing the process of converting to mm. But this is taking too long, and im wondering is there a add on or tool that I can use that makes things more simple were I could just type in the (inches) dimension and that would draw a line or what ever is needed to be drawing as a line in mm etc
Draw it in inches first, then scale it?
Hey Kate, nice to see you're still around, in one form or another 🙂
Ethereal or corpulent?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
...or should I say, one forum or another?...
Can someone give step-by-step instructions on how to do this? I am new to AutoCAD and have converted a PDF to DWG. The Insertion Scale lists "inches" yet the measurements on the drawing suggest metric. I have looked under UNITS and Dimension Styles but no changes have worked. I need to put the conversion factor of 10/254 or 0.039370079 in "somewhere". Help?!?!?!
1 mm is 1/25.4 inches. So, your scale factor will be 25.4 you can check MM to Inches
and to do it in CAD check the reference here - Millimeters to Inches
