AutoCAD LT General Discussion
New Member
huiberts
Message 1 of 3 (782 Views)
line scale problem in layouts
782 Views, 2 Replies
10-22-2003 07:11 PM
In layout 1 the dash-dot line shows and prints as a continuos line. The same line is in lay-out 2 the expected dash-dot. What's the way to make it show the right way in my lay-out 1. The same printer is installed, the same linescales are used ?
Frank
*Klasson, Conny
Message 2 of 3 (782 Views)
Re: line scale problem in layouts
10-22-2003 07:29 PM in reply to: huiberts
Is one of the lines zoomed out far?
Then you need to change the PSLTSCALE
to make the line type scales relative to paperspace.
Conny
"huiberts" skrev i meddelandet
news:f195a90.-1@WebX.maYIadrTaRb...
> Frank
*Byrnes, Dave
Message 3 of 3 (782 Views)
10-23-2003 05:25 AM in reply to: huiberts
Also, PSLTSCALE needs to be set for each
layout.
David Byrnes/Vancouver BC
Assistant Moderator - AutoDesk
Discussion Forums
In
are used ?
Frank
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD LT guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
