I want the preview to open a file to enlarge for better view thumbnails.
attached a picture so know q speak.
thanks for replying.
The previews are just small static bitmaps, so no matter how large you might be able to get the preview window the quality will not increase much, if any. If you use the Sheet Set Manager to open files, the preview window there is a bit larger. Windows Explorer (presuming you are on Windows) will also display a larger preview, but with the same aforementioned limitations.
it is a business which recomendas me ... but when you open an autocad drawing. I can enlarge the preview. no matter the quality of the image
attached image of how it goes now
attached picture of how he wanted
I also notice that depending on what version of AUTOCAD the file was last saved with, it may show larger or smaller in windows. Is there a way in Windows to have the .bmp size auto adjust ?
Ah thanks, close but no cigar; Probably would work but THUMBSIZE isn't available in AutoCAD LT. Only THUMBSAVE which just turns it on/off.
