AutoCAD LT Forum
.las layer state file not visible when importing
2 REPLIES 2
katie1994
883 Views, 2 Replies
OK, this is a new function for me. I  have several .dwg files from an architect each with several hundred layers. I set up a Layer State in one drawing with just the layers I need. I want to use the same Layer State in the other drawings. I opened the Layer States Manager, selected my layer state, and clicked export, selected a location and closed the widow.
I double checked in the file manger in Windows 7 that the .las file was where I had exported it. Then I opened the next .dwg, opened Layer States Manager, navigated to the file location and the .las file does not show up.
When I go back to the original drawing and click Import, the .las file is not visible either, but it is if I click Export.
Any ideas? I am working on drawings on my hard drive not a network, and saving the .las file to my hard drive.
2 REPLIES 2
katie1994
in reply to: katie1994
OK, never mind. I forgot to select the file type in the Import box.
Spoiler
pendean
Thank you for sharing your solution.
”Boost
