LT Version?
PDFATTACH in current shipping version. 2010 and 2011 versions as well.
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hello Charles,
Thank you so much for replying to my cry for help.
Unfortunately when I enter "PDFATTACH" it gives me a "unknown command"
When i use "insert" from my menu, I can import my OLE object, but i can't get the size.
Hope this makes any sense.
I operate AutoCad LT 2009
Thank you once again for your help.
Jacob Huyer
LT2009 does not have the ability to attach PDFs. Your best bet is to open it up in Acrobat and save it as a Jpeg.
Once you've done that you can attach the resultant jpeg using IMAGEATTACH
Howard Walker
Use the SNAPSHOT tool in your PDF reader to capture the image, then CTRL+V in LT2009 to get that image (not the PDF) in your file. Scale as needed.
Note that like all image capture tools, the bigger the image is on screen the better the capture resolution will be.
THANK YOU SO MUCH GENTLEMEN.
IT WORKS GREAT.
HAVE A GRERAT WEKEND, AND REVEL IN THE FACT THAT YOU MADE SOMENS LIFE BETTER.
JACOB HUYER
