OS: Windows 8, AutocadLT 2014 (both are newly installed on a new computer)
1. When I click Transmittal Setup on Standard
I get the following message:
Cannot find the resource string number 24474 in resource Acc Core 70
After clicking ok on the error message, i could still package my files. Its just that the error message pop up each time.
2. When I have a new Transmittal Setup, and I click on my new setup (not standard)
RESOURCE MANAGER ERROR
Unable to locate resource string. Rseource Manager is not correctly installed
then another error message pop out:
FATAL ERROR:
Unhandled access violation writing 0x0011 exception at 11h
then autocad terminates.
Any help is much appreciated!
I have also experienced a similar issue, if not the same issue.
Windows 7 64-bit, AutoCAD LT 2014
No matter the drawing, no matter the workstation. Any drawing I open and try to e-transmit I get this error:
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at e3e76f2eh
AutoCAD then crashes. It is unable to handle e-transmitting... this is serious as it prevents us from being able to coordinate our work between consultants.
Any help would be much appreciated.
I also am having issues that are very similar to what you are having. I recently upgraded to 2014 Lt/Windows 8.
I am learning the etransmit tool using Mastering AutoCAD 2014 and AutoCAD LT 2014 book by George Omura. I was following the instructions set on Chapter 27 and ran into these errors:
When I try to modify in the Transmittal set up I get a pop up that reads: Cannot find the resource string number 24474 in resource AecCore 70. After clicking Ok it goes to Modify Transmittal Setup dialog box
I also got a pop up that read: Unable to locate resource string, Resource Manager is not correctly installed
Any help?
