AutoCAD LT Forum
eTransmit resource manager error - Windows 8/Autocad LT 2014
4 REPLIES 4
1939 Views, 4 Replies
OS: Windows 8, AutocadLT 2014 (both are newly installed on a new computer)
1. When I click Transmittal Setup on Standard
I get the following message:
Cannot find the resource string number 24474 in resource Acc Core 70
After clicking ok on the error message, i could still package my files. Its just that the error message pop up each time.
2. When I have a new Transmittal Setup, and I click on my new setup (not standard)
RESOURCE MANAGER ERROR
Unable to locate resource string. Rseource Manager is not correctly installed
then another error message pop out:
FATAL ERROR:
Unhandled access violation writing 0x0011 exception at 11h
then autocad terminates.
Any help is much appreciated!
4 REPLIES 4
I have also experienced a similar issue, if not the same issue.
Windows 7 64-bit, AutoCAD LT 2014
No matter the drawing, no matter the workstation. Any drawing I open and try to e-transmit I get this error:
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at e3e76f2eh
AutoCAD then crashes. It is unable to handle e-transmitting... this is serious as it prevents us from being able to coordinate our work between consultants.
Any help would be much appreciated.
pendean
The first post seems to have a corrupt or missing AutoCAD core file: yours would appear to be unrelated to the exact issue at the top and ony have a single final symptom equivalent.
Can you, Shane G, post a screenshot of both of your eTransmit pop-ups? I can't reproduce the problem here in 2014 and Win7 64bit Pro.
Also, do you have another PC with LT2014 on it to test?
ngaxs
I also am having issues that are very similar to what you are having. I recently upgraded to 2014 Lt/Windows 8.
I am learning the etransmit tool using Mastering AutoCAD 2014 and AutoCAD LT 2014 book by George Omura. I was following the instructions set on Chapter 27 and ran into these errors:
When I try to modify in the Transmittal set up I get a pop up that reads:  Cannot find the resource string number 24474 in resource AecCore 70. After clicking Ok it goes to Modify Transmittal Setup dialog box
I also got a pop up that read: Unable to locate resource string, Resource Manager is not correctly installed
Any help?
pendean
Your file contains an object type your version of LT cannot handle; you either need to remove it, find an object enabler for it, fully patch/update/fix LT, or ask the file originator/creator that was not using LT to fix the file for you with -EXPORTTOAUTOCAD command.
There seem to be dozens of reports of the same exact issue over the years caused by this. Explore for other ideas: http://www.google.com/search?q=Cannot+find+the+resource+string+number
”Boost
