AutoCAD LT Forum
dwg compare plug-in
7 REPLIES 7
Message 1 of 8
AJAMP
2625 Views, 7 Replies
dwg compare plug-in
I was told that I should download and install DWG compage plug-in to compare 2 dwg files.  I have downloaded the file and installed it (at least I got the "successfully installed" message) but when I open AutoCAD LT 2013 it does not show up on the plug-ins tab and using the dwgcompare command returns an "unknown command" response.  Am I missing something in the initialization of this plug-in?
Mark
7 REPLIES 7
Message 2 of 8
Charles_Shade
in reply to: AJAMP
What is the link to this plug-in?
AutoCAD LT is not TurboCAD Pro.
Message 3 of 8
DarrenP
in reply to: Charles_Shade
i am assuming its the one from the exchange app store which doesn't work with lt only with full blown autocad and  the verticals
http://apps.exchange.autodesk.com/ACD/Detail/Index?id=appstore.exchange.autodesk.com%3adwgcompare%3a...
DarrenP
Message 4 of 8
AJAMP
in reply to: DarrenP
This is the link I was given.
http://apps.exchange.autodesk.com/ACD/2013/en/Detail/Index?id=appstore.exchange.autodesk.com%3adwgco...
We are using AutoCAD LT 2013 and I need to compare and combine edits that were made to the same file by 2 different editors 'simultaneously'.
Mark
Message 5 of 8
Charles_Shade
in reply to: AJAMP
On the right side there is a matrix that shows what this App is compatible with.
AutoCAD LT is not mentioned here.
Message 6 of 8
pendean
in reply to: AJAMP
No such tool exists for LT: sorry.
Message 7 of 8
scdait
in reply to: AJAMP
The exact same problem happened when I install it for Autocad 2015 (Full). Any advise what could be the problem?
Message 8 of 8
pendean
in reply to: scdait
Contact that add-on author through that website in the link way up top for help (even if it says Autodesk) and ensure it says it works on your version of AutoCAD and Windows.
”Boost
