Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
If you have a driver already installed in Windows that you can use in other programs, then you can access it in AutoCAD's PLOT command window too if you remembered to turn off HIDE SYSTEM PRINTERS in Options command's Print tab inside AutoCAD.
