Solved by eetjeernst25. Go to Solution.
Dear Dean,
I've got a little bit of trouble using the next macro in combination with the block. By my collegea's it's works really nice except on my system.
When I use the macro on the systems of my collegeas first I insert the block and the edit attribute diaogbox is coming up the screen. After OK end using the icon with the macro you see in the commandline some things come throu.When I do it on my system. I get the edit attribute box everytime I click a point but get no input on de x and y. In the dialogwindow (F2) i've get the message doesn't no the command xxxxx(varaible of the x or Y) see files.
I think it's a variabel because I copied the macro from my collegeas.
Colud you help me?
With regards Eric Ernst
