AutoCAD LT Forum
cannot open AutoCad Release 12 file with AutoCad LT 2010
6 REPLIES 6
NESGolden
495 Views, 6 Replies
When I try to open an AutoCad Release 12 file with AutoCad LT 2010, I get a "Drawing file not valid" error.  The files were backed up on a DDS-1 data cartridge and I had someone retrieve them.  So I am not sure if it was the retrieval operation or the AutoCad LT 2010.  Any ideas or solutions?
An example is attached.
6 REPLIES 6
DarrenP
in reply to: NESGolden
i think there is something wrong with the file
it doesn't open up in 2013 either same message
anyway to open it in release 12?
DarrenP
NESGolden
in reply to: DarrenP
Darren,
No I do not have that release.  The files appear to be okay. I guess I will contact the person who took them off the tape to see if he might have clue.  Thanks.
pendean
File header is messed up: AFAIK this cannot be fixed.
NESGolden
in reply to: pendean
How is it messed up?  Is this something that could have happened in retrieving the files?  What should an AutoCad R12 header look like?
pendean
Open a good DWG file in Windows Notepad: first thing at the top is a code the starts with AC10 plus othe digits.
Open the file you posted the same way: first line is something else.
The file may have been corrupt prior to storing, or storing/retrieval method may not have completed properly and messed the file up.
NESGolden
Yes, I saw that.  I mentioned that to the firm that retrieved the files and it looks like they can fix it.  Thanks.
”Boost
