AutoCAD LT Forum
can autocad lt reduce the size of a drawing
13 REPLIES 13
Message 1 of 14
jensenff
3770 Views, 13 Replies
I have some products that I make that a customer has asked if it would be possible to have them reduced by 50% is there any way anyone knows how I can do this quickly without having to draw them again.
13 REPLIES 13
Message 2 of 14
in reply to: jensenff
you could always try the SCALE command, maybe the clue is in the name.
Message 3 of 14
ali_b
That makes as much sense as infinity/2
Be Noice!
Regards Gary.
wrote in message news:5463217@discussion.autodesk.com...
you could always try the SCALE command, maybe the clue is in the name. Message was edited by: Discussion Admin
Message 4 of 14
jensenff
Gosh arn't you clever, ... tried that first but will only accept positive values and scales up in size I do not know how to scale down!! which is why i am asking the question.
Message 5 of 14
Charles_Shade
.9 would be pointless and imperceptible
.8 is to fit a little better than .9
.7 is just wierd
.6 would be a little larger than .5
.5 would be half
.4 would be .4
.3 would be 1/3
.2 would be one fifth
.1 would be one tenth
Good Luck, see the one in the middle (1/2). More than one
way to whack a cat.
regards,
cshade
Message 6 of 14
jensenff
fantastic will give it a go thank you very much indeed!!!
Message 7 of 14
jensenff
Once again thank you, made life a lot easier. It worked perfectly, I owe you one.
cheers
Message 8 of 14
Charles_Shade
Young's Oatmeal Stout in a can
regards,
cshade
Message 9 of 14
jensenff
just tell me where to send it, its yours
cheers
Message 10 of 14
Message 11 of 14
I have some products that I make that a customer has asked if it would be possible to have them reduced by 50% or more is there any way anyone knows how I can do this quickly without having to draw them again.
Message 12 of 14
Emmsleys
Hi @Anonymous,
Welcome to the Autodesk Community.
If your files have been worked on by multiple users and in different releases I normally recommend cleaning up your file. After running the below steps Iʻve seen a lot of files decrease in size in a noticeable difference.
  1. Run RECOVERALL, at the command line and select drawing, save drawing and close.
  2. Run RECOVER, at the command line and select drawing.
  3. (-)PURGE > Regapps > Enter>No
  4. (-)PURGE>ALL> Enter>No
  5. AUDIT> Yes
  6. PURGE > Select Purge nested items> Select Automatically purge orphaned data > Purge All
  7. (-)SCALESEDIT
  8. CTRL+A > OVERKILL (Warning: use this command with caution, running the command modifies your geometry by deleting objects you may need. Save a copy of the original file in case of any unwanted changes. )
  9. Close and Save newly purged file (ex. CLEANED_file)
  10. Apply workflow.
After cleaning up the file you can also use the WBLOCK command to export the specific information that you would want to send to a client or a co-worker. Let me know if that helps with your question.
Sarah Emmsley
Technical Support Specialist
Message 13 of 14
pendean
Delete half the content of your DWG file is a good place to start.
Message 14 of 14
Emmsleys
@Anonymous
Were you able to try anything suggested in the thread?
Sarah Emmsley
”Boost
