AutoCAD LT General Discussion
New Member
aishahacsb
Message 1 of 3 (121 Views)
autocad fatal error : not enough memory. Shutting down.
121 Views, 2 Replies
06-16-2014 09:23 PM
Every time I want to copy drawing from file to another, autocad keep crashing with this message. Any helpful solution. Already reset autocad to default. Still occur the same problem. Tia.
pendean
Message 2 of 3 (102 Views)
Re: autocad fatal error : not enough memory. Shutting down.
06-17-2014 04:04 AM in reply to: aishahacsb
System details?
Windows version?
LT version?
Size of the two files?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
ScottHodges
Message 3 of 3 (72 Views)
06-24-2014 09:53 PM in reply to: aishahacsb
That sounds like a windows resources problem. Try defragging, rebooting and shutting down everything except AutoCAD. Or the problem may be exactly as described: insufficient physical RAM to run AutoCAD as well as all the windows bloatware, and copy and pasting. Have you tried using wblock to extract the info from one drawing and inserting it in another, rather than copying and pasting. Also running in SDI = 1 may reduce the amount of resources AutoCAD requires and enable you to complete the copying
