AutoCAD LT Forum
autocad fatal error : not enough memory. Shutting down.
2 REPLIES 2
aishahacsb
750 Views, 2 Replies
Every time I want to copy drawing from file to another, autocad keep crashing with this message. Any helpful solution. Already reset autocad to default. Still occur the same problem. Tia.
2 REPLIES 2
pendean
in reply to: aishahacsb
System details?
Windows version?
LT version?
Size of the two files?
ScottHodges
That sounds like a windows resources problem. Try defragging, rebooting and shutting down everything except AutoCAD. Or the problem may be exactly as described: insufficient physical RAM to run AutoCAD as well as all the windows bloatware, and copy and pasting. Have you tried using wblock to extract the info from one drawing and inserting it in another, rather than copying and pasting. Also running in SDI = 1 may reduce the amount of resources AutoCAD requires and enable you to complete the copying
”Boost
