autocad LT 2008 on windows 7 platform
after using this with only minor crashes for the last year I have now got problems with closing drawings which then locks autocad up and if someone else opens the file in the same program on windows xp then it crashes there program too while closing. I have tried redraw the drawing model file and produce a new drawing sheet exactly the same but it still crashes on saving of the file and have now noticed that any drawing i'm creating now does exactly the same. I have also completely reinstalled autocad LT 2008 to try to fix this problem but with no success. Has there been an update either with windows 7 or autocad that might have caused this problem and could anyone please advise on how to resolve this problem as I am now left with a computer thats useless to draw upon and rather not install an older version of windows just to resolve this problem after it running fine for over a year now.
thanks
James Inight
Your own comment may be the solution:
What changed on the computer prior to the problem?
Go into system restore and see if there is a Windows update, generally a .NET, or have there been any programs added to the system?
Do you use Symantec products by chance? Any update there?
It may be worth rolling back the System Restore to prior to the problem.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
What else changed? I noticed you mention file coruption too. Did you reset the way LT2008 saves or something similar?
LT2008 is not supported in Win7: in case you did not know. Are you using Win7-64bit or Win7-32bit?
Windows 7 has built in tools that may shed light on what is causing the crashes, usually a DLL that got replace. Tricky to put back unless you truly uninstall LT2008, restart Windows, run a registry cleaner on your system to eliminate all issues found, and reinstall LT2008 and answer yes to all files being replaced: I would take the extra step and remove all .NET programs from your PC while you uninstall LT2008.
If that DLL is not touced by the installation, you might have to do other things: but you must identify the reason for the crashes first by getting your Win7 to tell you what that is... .
- Find out what's causing Win7 reliability issues (crashes or application hangs) type reliability in the Instant Search bar to open the Reliability Monitor; it will show your system's reliability history over a period of time and what seems to hit your reliability the most.
- See a system diagnostic of your computer in Win7: Either go to Administrative Tools, then to Performance Monitor, and finally to Data Collector Sets to launch the System Diagnostic DCS, or simply open up an administrator command prompt and type perfmon /report.
