renaming layers
renaming layers
Message 1 of 9
renaming layers
Why won't this work?
strOldString = txtOldString.Text
strNewString = txtNewString.Text
For Each objLayer In ThisDrawing.Layers
' Debug.Print objLayer.Name
Replace objLayer.Name, strOldString, strNewString
Next
Josh
Replies (8)
Message 2 of 9
this doesn't work either.
Dim strLayerName As String
Dim strOldString As String
Dim strNewString As String
Dim objLayer As AcadLayer
'On Error GoTo cmdOK_error
strLayerName = CStr(objLayer.Name)
Set objLayer = ThisDrawing.Layers(strLayerName)
Replace strLayerName, strOldString, strNewString, 1, , vbTextCompare
objLayer.Name = strLayerName
Next
Message 3 of 9
Try the following:
Dim tempstr
' Debug.Print
objLayer.Name
tempstr = objLayer.Name
Replace tempstr, strOldString, strNewString
objLayer.Name = tempstr
Next
Why
won't this work?
Next
Josh
Message 4 of 9
Have you checked to see if the information is going
into your str variables. I quote, "You can't access a control if it does not
have the focus." Try this
strOldString = Me.txtOldString
strNewString = Me.txtNewString
For Each objLayer in
ThisDrawing.Layers
    If objLayer.Name =
ThisDrawing.Layers.Item(strOldString) Then
        objLayer.Name
= strNewLayer
Next
Why
won't this work?
Next
Josh
Message 5 of 9
Well, it looks like you're iterating through all
the
layers [which if that's the case then you're
trying
to rename layer "0"]. Need I say more?
Joe
Why
won't this work?
Next
Josh
Message 6 of 9
not if you are iterating through them and only
looking to match an individual name to an individual string.
the
trying
more?
Joe
Why
won't this work?
strNewString
Next
Josh
Message 7 of 9
Well, that would depend on what he has in the
TextBox
which we don't know what that data might be. Also,
there
is no error trapping which I would add on this
particular
example to guard against that very
scenario.
Joe
all the
trying
more?
Joe
Why
won't this work?
strNewString
Next
Josh
Message 8 of 9
This is still giving me fits. The idea behind this routine was that my client could rename the layers in their drawing to change a certain prefix that they had added to their layers; and they have a fair number of drawings to edit. So, the strOldString variable is the old prefix, and the strNewString is the new layer prefix.
Private Sub cmdOK_Click()
On Error Resume Next
'For Each objLayer In ThisDrawing.Layers
'Next
Next
subExit
End Sub
What did I miss?
Joshua
Message 9 of 9
Josh,
Here's your answer. The Replace function returns
the
changed string which I then assign to the
Layer.Name
property accordingly.
Joe
Dim strNewString As
String
strOldString = UCase(txtOldString.Text)
  strNewString =
UCase(txtNewString.Text)
ThisDrawing.Layers
    objLayer.Name = Replace(objLayer.Name,
strOldString, strNewString)
  Next objLayer
This
layer prefix.
Dim
Dim objLayer As
AcadLayer
'Next
1, , vbTextCompare
Next
subExit
End Sub
What did I miss?
Joshua
