This message group came in with no subject line and attached
itself to a similar one from June, 2001. All messages copied
below and given a title so they can be more easily seen by all
viewers.
Anne Brown
Manager, Moderator
Autodesk Product Support Discussion Groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Re:
Date:
Wed, 15 Jan 2003 03:17:58 -0800
"Allan Lickander"
Newsgroups:
autodesk.autocadlt.2002general
Hi all
Where can I, one for all, set the property for the "leader"? I
must change it in every new drawing - annoying.
Med vänliga hälsningar
/With regards
Allan Lickander
Trädgårdsingenjör / Landscape Manager
Eslövs kommun
Miljö och Samhällsbyggnad
241 80 Eslöv
Sweden
+46 413 620 53
+46 70 521 20 53
allan.lickander@eslov.se
http://www.eslov.se/
Subject:
Re:
Date:
Wed, 15 Jan 2003 04:39:29 -0800
"Conny Klasson"
Newsgroups:
Have you tried changing the dimension style
and then save the drawing as a template?
Conny
Subject:
Re:
Date:
Wed, 15 Jan 2003 06:03:45 -0800
"Dean Saadallah"
Organization:
PenDean Inc.
Newsgroups:
... and then all you do is import that Dimstyle into existing
drawings as
needed.
Start DDIM, tap the HELP button, read about all the DIM variables
associated
with every option, then create a simple SCRIPT file or toolbar
button macro
that will at least preset all of those options when you need it.
HELP can
show you how SCRIPT and script files can be set up.
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
