Autocad LT 2014
Win 7
This floating icon/window (see attachment) has appeared in the upper right corner of my screen out of the blue.
I have clicked the little x in its upper right corner but nothing happens, it will not go away. How do I get rid of it?
Thanks.
Solved by nestly2. Go to Solution.
Thanks for the replies guys.
Resetting the NAVBARDISPLAY to 0 did the trick.
m
If it solved your problem then provide set "Mark accepted as solution" on the post that held your solution.
