AutoCAD LT Forum
What is this (floating window)?
6 REPLIES 6
marchitect_nc
889 Views, 6 Replies
Autocad LT 2014
Win 7
This floating icon/window (see attachment) has appeared in the upper right corner of my screen out of the blue.
I have clicked the little x in its upper right corner but nothing happens, it will not go away. How do I get rid of it?
Thanks.
6 REPLIES 6
pendean
in reply to: marchitect_nc
Navigation Pane.
Click on the faint X top right to close what you seem to have opened.
marchitect_nc
in reply to: pendean
Hi Dean. Clicking the faint little x doesn't do anything except start a selection box. I can't seem to get it to go away. Thanks.
nestly2
It's the NAVBAR  --> Link
NAVBARDISPLAY = 0 should turn it OFF  (but then again, so should the "x")
pendean
Yeah, I forgot: nothing we all can do you seem to can't do in LT2014 😉
marchitect_nc
Thanks for the replies guys.
Resetting the NAVBARDISPLAY to 0 did the trick.
m
AcadAdamLT
If it solved your problem then provide set "Mark accepted as solution" on the post that held your solution.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
”Boost
