AutoCAD LT Forum
Want to permanenlty send Mtext (with background mask) to front
2 REPLIES 2
architec-tor
1108 Views, 2 Replies
I have set mtext (with background mask on) to the foreground (using draw order: front, and draw order: above objects) but those settings do not 'stick' and often have to go back and reset all those values over again.
I've also tried using Draw Order on the objects under the text (draw order: behind) which also results inthe text randomly behind in front of or behind objects.
Is there a way to set mtext to be in the foreground permanently and not have to go back and mess with Draw Order all the time?
2 REPLIES 2
Draworder is Draworder if it comes later it will be on top.
TEXTTOFRONT may be a way to get everything on top with a Macro.
DRAWORDERCTL may be worth looking at.
Search Help for Commands for Object Visibility
pendean
in reply to: architec-tor
PS: you almost always have to REGEN or REGENALL to correct an occasional display hiccup. In addition to the variables noted above. Reality in AutoCAD.
”Boost
