So I have just upgraded from LT 2011 to LT 2014 and the only issue I have came a cross so far is getting right click to work using using my Wacom Bamboo tablet.
My Windows settings are set so "Press and hold = Right click" but it is not working in model space or paper space. It works fine on other applications just not AutoCAD LT 2014.
I am hoping that there is a setting in autocad I can't find to make this work. I had no problem in 2011 I just plugged it in and it worked.
Any help would be greatly appreciated
Thanks in advance.
Solved by whammer. Go to Solution.
Had the same problem. Tried disabling Press+Hold, but it didn't help. Finally found something that worked from this blog post:
http://blog.jorgenslist.com/post/74465654181/how-to-turn-off-wacom-pen-feedback-in-windows-8-1
In your Wacom Tablet Properties, under Mapping, turn off Windows Ink. It's on by default (at least in Windows 8.1). My right-click started working in AutoCAD 2015 and that annoying ring that also caused screen lag went away, too.
Thanks for this post on the right-click issue. Turning off windows-ink solved it.
