I have a vendor who sent me a drawing measured in Millimeters but is actually drawn in standard units. How do convert or scale this to a standard unit of measure?
That would be Imperial or possibly Architectural units?
And you may not want to Scale the drawing if it is truly 1:1 in Modelspace
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Be careful when doing brute force scaling between different unit systems - they aren't always the same. Some manufacturers produce both metric and imperial versions, with slightly different dimensions e.g. the metric product would have bolt holes on 110 mm spacing while the imperial product has bolt holes on 4.0" spacing.
