I'm having the same issue, and the suggestions is not working for me. The blocks in question are dynamic. How do I turn them off?
Freeze the layer they are on in the XREF.
if they are not in an XREF and you have a current version of LT, try the same method or for a temporary solution try HIDEOBJECTS command (UNISOLATEOBJECTS command to bring them back).
Could be Layer 0 needs to be off as well if these were created on that Layer.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
@Charles_Shade wrote:Could be Layer 0 needs to be off as well if these were created on that Layer.
Only if the blocks were inserted on layer 0 (zero). If the blocks were created on 0 but inserted on another layer (eg: Electrical) and the dynamic blocks have multiple layers on them then you need to FREEZE the Electrical layer rather than just turning it off. The FREEZE option will also stop the subsequent layers involved in the block from displaying.
DJ
Could be.
Thought that using those two words would be an additional thought for the OP not the only answer.
