AutoCAD LT General Discussion
Valued Contributor
mick_mcg
Message 1 of 3 (603 Views)
Transparent solid hatch plotting with vertical lines
603 Views, 2 Replies
02-05-2014 12:47 AM
Hi, When I plot a drawing with a transparent solid hatch within this drawing, it plots with horizontal lines across the hatch pattern as shown on attached file.  I know there is a work round by using a gradient hatch with the two colours set as the same, but is there any fix to stop this happening with a solid hatch pattern?  (using a solid gradient transparent hatch has caused another issue as it seems to have problems pdf'ing with dwg to pdf.pc3, as mentioned on another post)  This problem with the Transparent solid hatch happens when plotting to any plotter or PDF device and also with our pen settings set and no pen settings.  Problem happens in LT2012 & LT2014.
Thanks in advance!
Mick
Windows 7 Enterprise
14gb Ram
NVIDIA Quadro 2000
Active Member
anders_epost
Message 2 of 3 (381 Views)
Re: Transparent solid hatch plotting with vertical lines
04-08-2014 02:07 AM in reply to: mick_mcg
Cheers!
It is probably caused by the plotter, and not autocad itself.
Try plotting at higher quality. There is an option for plot quality in the autocad plot window.
At the default 'normal' setting my plotter allso leaves those lines, but not at 'maximum'.
Hope this helps.
Charles_Shade
Message 3 of 3 (360 Views)
04-08-2014 11:26 AM in reply to: anders_epost
Agree with the DPI for the PDF. You will need to drill down into the PC3 file for DWG to PDF.pc3 to up the DPI.
PLOTTERMANAGER, DWG to PDF.pc3, (double click), Device and Document tab, Custom Properties, Custom Properties...
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
You are not logged in.
    Come hangout with Autodesk Support Specialist and AutoCAD LT guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Ask the Community
