New to Autocad products.
I need to transfer all files from a deceased persons computer who was using Autocad 2011 to complete a project for one of his clients.
I have downloaded Autocad LT to see if this will be sufficient (only need 2d aspect for project). I need to be sure I get all required files, used hatches,fonts,etc.off the computer, but not yet sure where to look for these files or if indeed they can all be transferred.
I am confident that the drawing files can be transferred but question whether the hatch patterns and/or fonts can also be transferred.
Can anyone advise me regarding file extensions to retrieve and if I can transfer the autocad hatch patterns to autocad lt? I know there is a sheathing pattern which I would like to transfer, but not sure I can. The first trial transfer I received indicated that 2 reference files were not available and nothing showed on the screen except for a small preview which was not too descriptive.
What would be the best way to
Fortunately the project is not complex.
Thanks for your input or comments.
Ray
Win 7 Pro 64
Solved by pendean. Go to Solution.
Thank you Dean for you quick and informative reply, this is the sort of info I am trying to quickly assemble.
Learning Autocad will take longer.
Would you or others know if I will be able to transfer and use those hatch patterns that may be on the autocad computer over to my autocad lt computer or will I need to create my own to match? Is there an Autocad restriction on this? I can understand if there is one but would be dissapointed.
My access to the computer should be universal and hopefully the files structure will make it relative easy to locate the files. If I bring up an existing file, is there a procedure to display where those reference files might reside?
Ray
