**TB_ELECTRICAL_SYMBOLS_2
ID_Elec_Sym_2 [_Toolbar("Electrical Symbols 2", _Right, _Show,
1, 0, 1)]
ID__2 [_Button("2W",
"2w.bmp", "ICON_24_BLANK")]*^C^C-insert;2w;scale;$M=$(eval,$(getenv,dwgscale))
The '*' causes the command to repeat. '-insert' calls the command
line version of the insert command. '2w' is file 2w.dwg. 'scale'
calls the scale option of the insert command. The '$M...' retrieves
the stored scaling value and passes it to the insert command. Selecting
the insert point is the next normal step for the insert command and requires
no entry in the command string.
The dwgscale variable gets set by another button:
**SCALES
ID_Scales [_Toolbar("Scales", _Floating,
_Hide, 234, 206, 16)]
ID__0 [_Button("1/8
Scale","1_8.bmp",
"ICON_24_BLANK")]^C^Cucsicon;off;blipmode;0;gridmode;0;snapmode;0;ltscale;24;setenv;dwgscale;96
Note that each line that starts 'ID_' should be on a single line.
Your browser may split longer lines.
Martin
Tony Brookes wrote:
I wish to
create a number of toolbar buttons which will enable symbols to be entered
into a drawing.I do not
wish to be prompted for the symbol scale (1:1) or rotation ( zero ) each
time I call up a symbol, these will be the same for each symbol. I would
like to position the symbol on the drawing using the pointing device once
the symbol has been loaded. The
symbols and the associated button bitmaps will be stored within a sub-directory
of ACADLT. The principal
problem seems to be that, when ACADLT sees the insert prompt, it automatically
brings up the sub-menu requiring entry of position, scale and rotation.
Is the answer to disable the sub-menu, if so, how is this achieved. I
would appreciate some assistance. Regards, Tony
Brookes
"Martin Shoemaker" <Here's
href="mailto:hmspe@cableaz.com">hmspe@cableaz.com> wrote in message
href="news:3A536740.8B16A6DB@cableaz.com">news:3A536740.8B16A6DB@cableaz.com...
a clip from my aclt.mns file:
Symbols 2", _Right, _Show, 1, 0, 1)]
calls the scale option of the insert command. The '$M...' retrieves the
stored scaling value and passes it to the insert command. Selecting the
insert point is the next normal step for the insert command and requires no
**SCALES
_Floating, _Hide, 234, 206, 16)]
ID__0 [_Button("1/8
Scale","1_8.bmp",
Martin
Tony Brookes wrote:
I wish to
into a drawing.I do not wish to
be prompted for the symbol scale (1:1) or rotation ( zero ) each time I call
up a symbol, these will be the same for each symbol. I would like to
position the symbol on the drawing using the pointing device once the symbol
sub-directory of ACADLT.
size=-1>The principal problem seems to be that, when ACADLT sees the insert
prompt, it automatically brings up the sub-menu requiring entry of position,
scale and rotation. Is the answer to disable the sub-menu, if so, how is
this achieved. I would
size=-1>Regards,
size=-1>Tony
Brookes
