AutoCAD LT Forum
System variable to Maintain Polyline Width when joining non-polylines
8 REPLIES 8
Message 1 of 9
architec-tor
1953 Views, 8 Replies
Example:
Existing polyline set to a width of 6. Want to fillet this to a non-polyline with a width of zero.
Currently the two lines will join to create a connected polyline but the original widths are maintained (6 and 0).
I am looking for the system variable where the non-polyline becomes joined and the global width for the new segment matches the first polyline.
Thank you.
8 REPLIES 8
Message 2 of 9
pendean
in reply to: architec-tor
No such option.
Message 3 of 9
architec-tor
in reply to: pendean
Are you sure because that's the way it's been working for many years and all of a sudden it's not working (within the last few weeks).
IThere must be a system variable for polyline joining that associated all new segments to match the original polyline!
Message 4 of 9
maxim_k
I just checked:
In AC 2007 when you join (or fillet) polyline with width assigned greater than 0 and line object, than resulting polyline takes width from polyline - exactly as you write. But when you fillet (join) two polylines (one with width=0 and the other with width>0) - than the width of segments stays different.
In AC 2012 .... 2014 the width of attached polyline segment never changes when filleting (joining) with line or with polyline.
Seems that there was something changed in AutoCAD itself since 2007 release.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
steven-g
in reply to: maxim_k
Apparently it changed in 2012, I found this link for a lisp routine to do things the old way http://autocadtips.wordpress.com/2012/12/31/autolisp-fillet-and-match-pline-width/http://
Message 6 of 9
maxim_k
Hi steven,
Sorry, but there is an extra "http://" in your link, it should look as:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
pendean
in reply to: steven-g
No lisp in LT, no variable in LT, no way to go back in LT.
Message 8 of 9
steven-g
Indeed that was carelessly worded, I was just trying to show that the behavior had changed and that it wasn't a variable, I didn't really mean to imply that it was a fix in this case.
Message 9 of 9
pendean
No worries, just wanted to control 'expectations' should LT users get all excited 🙂
”Boost
