One of our AC08LT workstations is very slow on Copy / Paste command... Not bound to one dwg... Happens with any dwg. Any suggestions?
djboer
It would seem to me the old age problem of " scalelistedit ". These are Autocad annotative scales which are automatically generated from Autocad 2008 on.
Type SCALELISTEDIT and delete any scales that you dont use, I usually just have scales 1:1 and create new scales when I need them.
If the scalelistedit dialouge doesn't come up then try typing -SCALELISTEDIT and then R (for reset) this creates a shorter list which now the dialogue box can show and then delete unwanted scales.
If if works now look for scalelistedit utility program on the discussion forums.
These scales are generated on all your drawing files (drawings, blocks, xrefs, etc) and you may need to delete all your scales in all files otherwise they are re-inserted when you insert a block or xref files in.
Hope it helps
I've tried all these solution and I'm still having this issue. My current drawing is completely locked up and it is a very basic line drawing of a residential lot, no floor plan. I have this issue on other dwgs but I've been able to purge, reset filters, remove XREFs and it works. Never had this issue before until my upgrade to ACADLT17.
Any help is appropriated I'm growing tired of this issue and it is slowing down my drawing time and losing me $$$.
Thank you for the answer.
There are no XREFs in this drawing. Its very small and uncomplicated. I had already done a purge, recover, deleted as much info as possible, deleted layer filters and basically reset everything. Not seeing a solution I went old school and copied everything into a drawing file that wasn't having the issue. I had to wait about 10 minutes for each copy command to get the model and paper space line work moved. This seems to have worked for now.
I'm continuously having this issue with a lot of drawing files. This was the worst so far and on my smallest file.
I had the exact same problem even when starting a new drawing but realised i was using our company standard template border which seemed to create the problem.
This company template worked fine when using Acad 2016 but seems to have an issue when i imported it into autocad 2017.
However when I used the standard autocad border as a test the time lag disappeared and it worked fine. I then deleted the ACad standard border & copy & pasted my old border over the top and it still worked fine.
Im not sure what caused the issue in the first place but this solution worked for me . New template -no issues!
When I copy, paste in new location then hit esc or enter my drawing freezes for about 20 seconds or more. any Fix to this?
This is the easiest and most effective solution I've used:
Type Command > "wblock"
Under Source > Select "Entire Drawing"
Under Destination > Select the path you would like to "Save" to (usually the same location) or (move to a different location like DESKTOP, then move to the folder need to overwrite the drawing that has slow copy/paste issues once that drawing is closed)
Click > "OK"
Go to the "Destination" (path) you provided for the drawing to be saved in
Open the drawing and Copy/Paste functions should be working properly!
This has fixed the issue for me EVERYTIME!!!!
Wanted to ask clarification from @colin.barilleaux : are you saying once this is done, open the .DWG you were working in already, or open the new .DWG you just made (on your screenshot titled "wblock.dwg")?
Clarification needed from @Anonymous : Is there a step you're leaving out? When I type LAYER I just get a menu of all my current layers, and I don't see this "delete all layer filters" option you speak of.
