AutoCAD LT Forum
ScriptPro 2.0 shell command failed. unable to open file en-us.dwg
3 REPLIES 3
1676 Views, 3 Replies
Greetings,
I just installed ScriptPro 2.0 and used it successfully yesterday. Today when I try to run ScriptPro this error pops up  each time I try to run a script on multiple drawings:
I tried reinstalling ScriptPro and that didn't seem to help.
I am running AutoCad LT 2012, Windows 7
Thanks for any help,
DRW
3 REPLIES 3
pendean
SCRIPTPRO is not designed to work with LT, and not intended to work with LT, says so in the HELP file:
http://images.autodesk.com/adsk/files/Readme_cct.html
Perhaps you ran it using AutoCAD (not LT)?
in reply to: pendean
Oops my mistake. I ran it first on the sick guy's computer, he has full autocad. I have LT. That explains it.
Doug
PatrickByrne
Our program Multi-Batch can do this and a lot more. It gives you the power of AutoCAD's full version utilities ScriptPro and Publish in an easy to use single package.
It has five wizards for creating new routines including two for plotting, plus plenty of standard routines to get you started.
A fully working demo can be downloaded from http://www.multi-batch.com
Patrick
”Boost
