AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Ribbon
3 REPLIES 3
brian
287 Views, 3 Replies
Ribbon
Hi, just upgraded from 2004 to 2012.  Wow, sure looks different.
I'm playing around with the ribbon & don't know how to stop an annoying behavior.  I position the ribbon locked to the side of my display because I have a wide screen & if docked to the top I end up with a very wide, skinny drawing area.  Unfortunately, whenever I make a change tp the ribbon contents it goes back to the default top position, after which I have to relocate it again.  Is there a way to get it to remember the previous position of the ribbon?
3 REPLIES 3
Charles_Shade
in reply to: brian
Not sure if this will do what you seek but have you Saved the Workspace at any time?
brian
in reply to: Charles_Shade
that worked - thanks
Charles_Shade
in reply to: brian
Glad to help
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
”Boost
