AutoCAD LT Forum
Resource Manager Error 2014lt and 2015lt
4 REPLIES 4
biedanne
2005 Views, 4 Replies
Over the last few days, I have started getting a Resource Manager Error "Cannot find the resource string number yadda in resource AecCore70"
I can get out of it by hitting enter or escape several times while the stringe number changes, but it is a pain.
It is happening on drawings that I have used and updated for years, from an engineer that I have worked with for a decade, and with a new drawing that just came in. I've been using 2014lt, so I tried it in 2015lt (not using that until I can turn off the stinkin' badges), and had the same issue. I checked the properties of two and they are AEC_MVBLOCK_REF. Exploded they give me no trouble.
I can't think of anything that has changed in my system.
Ideas?
Windows 7 Pro, SP1, 64 bit
16GB RAM
NVIDIA Quadro 2000
4 REPLIES 4
pendean
in reply to: biedanne
There have been variations of that error for quite some time: are these files from AutoCAD Civil (or REVIT)? Or were contents in those files copied from AutoCAD Civil (or a DWG file from REVIT)?
Popular solution:
- Open the file(s) in question in AutoCAD Civil3D (as high/new a version as possible) and "export to autocad" from there to destroy/remove the content.
- Try and do the same in LT2014/2015 using -EXPORTTOAUTOCAD command (there is a dash in the name).
- Ensure LT2014 is fully patched/updated.
- Repair reinstall LT.
- There is no Civil Object Enablers for LT for that possible fix is ruled out.
There are a few more options posted: https://www.google.com/webhp?tab=ww&ei=ogNQU8q6EKiEygGVx4GQDQ&ved=0CBMQ1S4#q=Cannot+find+the+resourc...
biedanne
in reply to: pendean
Dean,
-EXPORTTOAUTOCAD from AutoCAD 2014lt worked. But that seems to be a file by file solution. But, then again, better than nothing.
2014lt is fully updated/patched.
I do not know what programs are used to create the files I am provided by outside engineers.
I may try a re-install and see if that gets rid of it all together.
Thank you for your help once again.
Anne
biedanne
Re-installing had no effect.
pendean
I suspect that export option is removing the AEC object "problem" your files contain. Glad it worked.
”Boost
