AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Reducing vertices in PLINEs
3 REPLIES 3
RLStanford
2574 Views, 3 Replies
I'm using AutoCAD LT 2011. I like the feature whereby I can 'hover' over a polyline vertex and then select 'delete'. Neat. However, when I offset a polyline, the new polyline always has about 10,000 vertices and I'd like to simplify it. Even with the 'hover' feature it will take me until Christmas to simplify the offset polyline. Is there some way to 'weed' the polyline vertices - that is, eliminate many at once rather than one-at-a-time? I've tried holding down 'Ctrl', 'Shift', and 'Alt' when selecting vertices - no joy - no multiple select that I've been able to find. Otherwise, is there some sort of system variable (or some other trick) that I'm not aware of that will keep me from generating so many vertices on the offset polyline? Thanks.
3 REPLIES 3
in reply to: RLStanford
Are you offsetting a splined
pline?  If so, decurve the original before offsetting.  Offset then
spline them again.
John
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
I'm
RLStanford
John -
Thanks - that solved a lot of the problem. I still have some PLINEs that have jillions of vertices (that I got by importing someone else's contour lines) - but at least I can work with the PLINEs that don't already have all those vertices. You just saved me 90% of the work I would have had to do.
Charles_Shade
That has MACRO written all over it.
Regards, Charles Shade
”Boost
