I need to redefine a number of Blocks in numerous existing drawings. I have redrawn the Blocks and Wblocked each of them to individual drawings. From within a drawing that requires the redefinitions I run a script to insert the new version eg:
-insert
detector=C:/.../detector.dwg
the command asks for an insertion point - since I do not need to actually insert a copy of the Block, I press ESC at this stage.
I then repeat this with the appropriate script for each of the Blocks to be redefined.
I have tried to create a combined script to redefine all the Blocks in a single operation by inserting ESC between the lines eg:
-insert
ESC
-insert
alarm=C:/.../alarm.dwg
but this doesn't work - the script hangs at the first insertion, asking for the insertion point - pressing ESC simply terminates the script.
How can I get the script to skip the insertion and go on to the next?
Something to read on Scripts: (Can I use the same answer twice?)
http://www.ellenfinkelstein.com/autocadtips/AutoCAD_tips_automate_scripts.html
What if you added 0,0 as the insertion point and then maybe an ERASE; Last; to the Script? (the Colons here are punctuation)
Can that be done?
SWAG - to this one
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
