Hi All,
A noob needs some help here. Usually when we enter RECTANGLE command, AUTOCAD will ask us to specify first corner point, then it will ask coodinate of second corner point.
Can the RECTANGLE command be set to straightaway insert dimension instead of coordinates?
Previous computer I used could do this, but this new computer can't. I don't know where to set it. Both computer using the same version of AUTOCAD LT2013. I reckon it could be set, but how?
Solved by maxim_k. Go to Solution.
Solved by hwalker. Go to Solution.
Welcome to the Forums
Yes it can.
The two special characters you need to know are # and @, the # command will give absolute co-ordinates
eg start your rectangle at 10,10 and put in #5,5 and your rectangle will draw it's last co-ordinate at 5,5 BUT
the @ command will give relative co-ordinates
start your rectangle at 10,10 and put in @5,5 and your rectangle will draw it's last co-ordinate at 15,15
also note to draw a relative rectangle in the opposite direction just put a - in front of the value.
Howard Walker
Additionally, there's a [D]imension option, just pay attention to the command line.
Command: _rectang
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]:
Specify other corner point or [Area/Dimensions/Rotation]:
If you have Dynamic input ON, than with default settings (Pointer input -> Relative coordinates) you can use dimension input even without typing @:
Start RECTANG command, pick first corner point, than type horizontal size, hit Tab button, type vertical size and hit Enter.
Maxim
@wordiotic wrote:
Really?
Yes, I'm not kidding.
Could you post hardware specs of your PCs?
Are they laptops or desktops?
Maxim
I posted this reply on a different string with the same issue... here's what your looking for:
turns out this is all fixed by a setting under your "snap" menu.
1. right click on your "snap" button at the bottom of the screen, and select settings.
2. to to the "dynamic input" tab.
YEAY! you can make rectangles in one move now! and sloped lines without drawing a 3 step triangle! sorry it took a year for someone to answer this for you!
I am having a slightly different problem that I can't seem to fix. I previously used AutoCAD 2016 and at my new employer I am now using AutoCAD MEP 2015. I used dynamic input all the time and my previous job and I used it the same way as Maxim shows in his video. Now, with this new system, messing with all the DSettings I can't seem to get it to work as a relative coordinate to the pick point. When I hit Tab after entering my X value, it immediately recognizes that X value as the absolute X value (3) in this case, instead of +3 units to the right.
See screenshot below:
It appears to be dealing some fashion in absolute coordinates instead of relative. But no matter how I set my dsettings and even polar tracking settings it always seems to do this. It must be some system variable I just don't know about!
Please help, I miss making rectangles with fewer clicks the way Maxim showed!
Warren
Did you try the enable pointer input suggestion i posted just above yours?
I did. Also, DSETTINGS is the command (just an fyi) to get to the dynamic input tab instead of clicking down at snap options and navigating over.
I realize now that this is the AutoCAD LT forum, but it seems like something maybe between all AutoCAD settings.
Very cool! Thank you Warren13 and leilang for inputting direct measures for a rectangle using the dynamic tool and the tab. I'm trying to learn AC on a Mac and having a heckuva' time.
Question: Is there a way to offset a rectangle, or any shape, by selecting and inputting a dimension? Thanks
Yep it's called OFFSET
Then you type in your distance. Then select your object and where you want to offset it to
Howard Walker
