AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
RFA viewer?
8 REPLIES 8
Message 1 of 9
madcowscarnival
28082 Views, 8 Replies
RFA viewer?
Does autodesk produce a free RFA viewer?
If not, is there an alternate program that can import/convert rfa files?  For example, Bobrick produces item specs in an rfa file only; I would like to view/import the file into a dwg of mine.  It is not critical that it be imported directly, but at least to see it on screen to confirm the specifications.
Most likely I can contact Bobrick for a converted file, but that takes time and unecessary resources, and is only a solution for their specs.  I have come across rfa files only from other mfg's as well.
8 REPLIES 8
Message 2 of 9
DarrenP
in reply to: madcowscarnival
are these revit family files?
 if they are revit has a free viewer when you install the program
DarrenP
Message 3 of 9
madcowscarnival
in reply to: DarrenP
Yes they are revit programs.  Do I need to install a trial version of the software for the viewer?  And does the viewer remain functional after the trial has expired?  Thanks.
Message 4 of 9
I believe I read yesterday that the Viewer will remain.
Message 5 of 9
DarrenP
yes and yes
DarrenP
Message 6 of 9
anthonyleewatkins
I have an architect sending me a rfa file, i do not have any autocad software on my desktop, but i dropped it in the autodesk veiwer, which says it views rvt files, but says
We're sorry, that file format is not currently supported
Please try a different file.
Help!!!!! Thanks
Message 7 of 9
pendean
in reply to: anthonyleewatkins
So why don't you need to ask the architect for a file format you can use???
Otherwise you need install REVIT (the version your architect is using): it becomes a free RFA viewer once the 30-days trial version expires. But it becomes just a viewer, nothing more. It's more than a viewer for as long as you are in the 30-day trial.
Note about REVIT versions: they change file formats with EVERY year version, so if you already have a viewer from back in the day or your architect recently upgraded then your old viewer is now dead and useless.
Message 8 of 9
j.harter
in reply to: pendean
Bc, it takes an hour to download and install revit, best case scenario, the software is heavy, and impractical as "just a viewer"
if a customer wants to preview a BPM family there should be a way to do so online, come on autodesk, pick up the pace.
Message 9 of 9
pendean
in reply to: j.harter
Autodesk provided viewers are explained here http://www.autodesk.com/viewers/all-viewers
”Boost
