I have problem in AutoCAD LT. When I select some object and look at properties. There is no selection in the properties window. See the image attached.
What could be the problem?
Have you run a registry cleaner recently, or uninstalled Autodesk360?
Properties Palete blank after selecting object
That is the Quick Properties window on top of the Palette properties window in your screenshot.
Are there any choices for QP for the entities that you have selected?
You can check by choosing the small box with the Check mark Icon which is how to Customize this pane.
Though I agree with Dean that the largeer heaer box is typicall not empty and the solutions offered in his post are the most typical reasons for this happening.
Any Windows updates recently?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I also have this problem, usually towards the end of the day. Seemingly out of nowhere, after selecting an object, I am unable to deselect an item. Also once I try to select an item, I check the properties pane, and it displays "no selection", but the item I have selected remains highlighted. I'm unable to move objects using grips. The only resolution I have found is to save and close my drawing. Then, close & reopen AutoCad.
