If you have ATI graphics cards in those machines, hop on ATI's website and
get updated drivers. Also explore turning down or off video card hardware
acceleration in Windows>Control panels>Display... . Also make sure you are
not running the video cards at maximum settings (no need for 32bit True
color and 1600x1200 maximum setting, refer to recommended settings by
manufacturer).
Also update your mouse drivers (MS Intellimouse work best, it does not
matter who's mouse you have), make sure your Windows is up to date with all
it's patches. Place LT in the Exclusions section.
All your add-ons (ZIP drives etc.) need to have updated drivers too. Your
anti-virus software needs to be turned off (or set to default factory
settings at best): remove any so called 'crash-proof' software if you got
it.
There are also patches for LT2002 that address graphics issues, see if that
helps too.
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
"Michael Barb" wrote in message
news:E5C56B074598D238F094BB7A86257126@in.WebX.maYIadrTaRb...
> We have 4 copies of LT2002, all running on Windows XP Pro on new Dell
> computers. All computers are different models. All continue to crash and
> there is a pattern that is starting to emerge. I am wondering if others
are
> seeing it.
> Those with the most crashes are the fastest ones. It usually happens when
a
> menu or box is being pulled down, and icon is hit, a popup box is about to
> appear, or change of focus from the drawing window to some other window
like
> properties. All of these generate Windows interrupts or commands from
> Windows that are passed to the AutoCAD. It generally happens when these
are
> called up very quickly after some other command is executed. It seems
like
> when AutoCAD is not finished with one command and Windows issues another
one
> it crashes AutoCAD.
> Usually there is a warning before the shutdown. Often recovery files are
> generated but not always. On rare occasions Windows just closes AutoCAD
> immediately.
> This kind of bug would be very hard to find and deal with. Every piece of
> code in the program works fine by itself. It is a matter of the timing
> between two commands.
> Again, is anyone else seeing this????
> Yours truly, Michael Barb
