AutoCAD LT Forum
Problemi con il mouse acad lt
3 REPLIES 3
valter.isonzo
311 Views, 3 Replies
Buongiorno, dopo l'installazione del prodotto il mouse prosegue "a scatti".
ho disattivato lo snap, controllato le impostazione del mouse ma sopra ai menu scorre velocemente, sulla finestra grafica ancora "a scatti". Può essere la scheda grafica?
Grazie
3 REPLIES 3
hwalker
in reply to: valter.isonzo
Welcomie to the forums.
From reading your post I assume that the mouse jumps a certain distance when you move it?
If so, look at the bottom left of your screen. There is a row of icons. The left one is called 'SNAP MODE' Make sure that is NOT on. It should be grey instead of blue.
Howard Walker
Left Handed and Proud
valter.isonzo
in reply to: hwalker
Snap mode is off...
Some informationon your Hardware setup and OS as well as the LT vesion please.
There are two posts here that talk about slow performance with LT. I am wondering if yours may be similar.
”Boost
